Water Pump
Yea I am still looking for that mythical LH AUX radiator!
Saw it in the manual a while ago and have been looking on EBay but it must have been pretty rare because nothing has ever showed up.
Read a rumor it was only available on middle east cars.
With all the cooling issues these cars have an additional radiator might be worthwhile?
Hey Mike,
If you've gone to the trouble of removing the under tray, why not replace the crankcase plug with one of these
You could then use a hole saw to cut an access point in the tray, maybe even a hole plug to cover the opening.
You would then be able to perform a proper oil change on the vehicle and be the envy of the rest of us
Baltobernie;
Great minds must think alike. I was toying with the idea of adding an access door to the under tray once I saw that the engine has an actual drain plug on the oil pan. I also like the Fumoto Drain Valve. I will do a post once I do the installation. May be a month or so before I post it.
Oil Pan Drain Plug / valve?
Hey Mike,
Cut a hole for a oil sump valve and also a hole for the oil filter?
I think that negates checking other things performed with the air deflector tray dropped like Accessory belt wear marks on the tensioner pulley, and detecting other leaks or inspections.
Oil Sump Plug / valve
But definitely a good thought for the valve which I have seen before but never gave it serious consideration until I went to do an oil change with the full air deflector in place.
On my XJ the air deflector needs some fixup at a few attachment points anyway from bumps/scrapes and DPO/DPM, so it will be a good time to have a look at those time saving options.
Candy's Kitty
09-19-2012 02:41 PM
Timothy
05-16-2012 07:14 PM
SteveM
10-12-2010 09:57 AM
AntixSD
04-03-2010 07:40 AM
