XJ ( X351 ) 2009 - 2019
water pump and all plastic
Old 01-02-2020 | 04:54 PM
BoomBoomZ31's Avatar
Exclamation water pump and all plastic
Good afternoon, I have a 2014 xjl 5.0 supercharged with 55k miles, bought at 34k, dallas
I recently started smelling coolant after every drive and over the past 2 months since I noticed it I've had to add coolant twice when it went about an inch below the fill line.
I haven't tried to locate where the leak is coming from since I'm planning on replacing everything.
After reading through all of the water pump replacement post it was noted that i should go ahead and replace all of the plastic as well, specifically the tube, front and rear crossover pipes and the ones on top that break when you're impatient. and in a few videos some of the rubber hoses were ripping during removal/installation. not sure of the names of the common ones.
also, should i get all of my parts from a dealer? or dealer website (PLEASE let me know what website) or trusted part i don't mind paying a premium to get OEM but if there is an aftermarket option that just as good for some of the hoses or other bits i would be great to know.
i know the supercharger has to come off for the rear crossover, I'm concerned about post saying it gets stuck, hoping it will be easier on a 2014. any tips?
what is the actual part name for the crossover pipes, new designed y pipe that has one outlet plugged?
and if you think any of the below parts are overkill please let me know which ones
would you consider the below list all of the pipes/hoses that should be replaced?
Newest Water Pump Assembly-AJ813909
Gasket-AJ813609 (is this really $26 for 1?)
Outlet Tube-C2Z18658
Oil Cooler O-Ring-AJ811539
Thermostat Unit -C2Z19929
Cooler Pipe- C2Z22073
Water Pipe?-C2Z28258
Outlet Pipe-AJ813917
Outlet Pipe O-Ring-AJ811350
Water Pipe?-AJ814007
Seal-AJ811600
coolant temp sensor? necessary?
Reservoir Hose-C2D56299
Vent Hose-C2D6362
Upper Hose-C2D25041
Lower Hose-C2D23172
Water Hose-C2D6007
Outlet Hose-C2D2323
Return Hose-C2D23749
Heater Hose-C2D27906
Inlet Hose-C2D5710
Inlet Hose-C2D6006
Inter-Cooler Hose-C2D24902
Inter-Cooler Hose-C2Z4544
Hose-C2C26617
Inter-Cooler Hose-C2P25496
Oil Cooler Tube-C2Z4537
Hose upper-C2P17026
Hose lower-C2P17027
since im pulling the supercharger off:
oil?
coupler?
Supercharger Belt-C2D39175
Belt Tensioner for SC-C2D49666
are there any parts im missing?
sorry for the long post just trying to order everything so i don't have to have her down too long.
any and all help is greatly appreciated
Jordon
Old 01-02-2020 | 10:28 PM
Nedoerr's Avatar
Most of the hoses and connectors you referenced I only found sourced by Jaguar. For dealer-sourced parts, I use:
https://parts.jaguarcarlsbad.com/
For the supercharger coupler you can get the solid oil-filled type from eBay (should prevent repeat of damage). I bought the whole Jaguar supercharger service kit from eBay, which includes the spring-type coupler and whole supercharger snout. This worked out well as my s/c snout was damaged by the coupler. On the downside I will have to do it again in 80k miles as I used the spring-type coupler again.
The supercharger oil is the AC Delco stuff for GM engines. You can find this many places but it’s nasty stuff so wear protection and use in well ventilated area.
There are members who can better answer your questions on various part numbers for just the cooling system. However I did post a list of parts I used for a similar job on post 59 here:https://www.jaguarforums.com/forum/x...-214277/page3/
There are some other posts in this thread that comment on other coolant hoses, so you may want to read the whole thread.
All the best.
Old 01-03-2020 | 11:03 AM
Thanks this helps a lot! unfortunately now I feel like I'm on that edge of the parts hole where you can start to justify buying more and more parts since "you're already in there". I'm planning on buying everything this weekend and taking my time with the repair. once again thanks for the reply.
fyamin
XF (X260)
06-12-2020 02:36 PM
Escolar
04-13-2020 11:24 PM
hafren
01-26-2020 04:46 PM
S-Typer
11-20-2018 03:53 PM
Bones28
10-21-2017 07:36 PM
Quick Reply: water pump and all plastic
