XJ ( X351 ) 2009 - 2019
What did you do to your X351 today?
Old 05-31-2024, 01:40 PM
XJsss's Avatar
does the float come to the top of the fluid? If no check the collant/water mix as if to much water the float will not rise.
  #562
Meanmugga's Avatar
Finished my ADH camera install. Going to connect the digital mirror next.
The following 3 users liked this post by Meanmugga:
dmchao (05-31-2024), lotusespritse (05-31-2024), QP7 (06-02-2024)
  #563
Old 05-31-2024, 01:48 PM
dmchao's Avatar
Odd. I had that happen to mine, the sensor seems to wear out over time. It's built into the coolant expansion tank, my guess is you can just replace that. It takes 30 minutes or less.
  #564
Old 05-31-2024, 01:54 PM
Paldi's Avatar
Originally Posted by XJsss
does the float come to the top of the fluid? If no check the coolant/water mix as if too much water the float will not rise.
I don't know where the float is.
  #565
Old 05-31-2024, 02:46 PM
lotusespritse's Avatar
That's a good idea. I'd like to see how the image looks when you're all done. I am a little concerned the camera is going to pick up a lot of reflection day and night off the white roof and cause an issue with auto contrast.
  #566
Old 06-01-2024, 05:19 PM
Paldi's Avatar
I can't see it. If I look into the tank (cap off) is the float supposed to be right there?
  #567
Old 06-02-2024, 12:42 AM
Meanmugga's Avatar
So far so good. I can adjust the angle of the lens as well.
I will update once I run the wire to the front
lotusespritse (06-02-2024)
  #568
Old 06-12-2024, 06:41 AM
Paldi's Avatar
Dealer replaced one of mine under warranty. If I never use them, could they still eventually break?
  #569
Old 06-12-2024, 07:34 AM
Paldi's Avatar
I'd like to do something like that on mine.
  #570
Old 06-18-2024, 11:23 AM
Vasara's Avatar
I took my XJ to the MOT today.
No markings, exept the crack on winshield, what is ordered but take 2 months to arrive.
Diesel smoke test result was 0,01 what tells that everything is still Ok on my engine, even after 14 years and 316tkm (197t mil).
(been thinking that it start to be time for newer car, but why and if, then what next? )
  #571
Old 06-18-2024, 11:45 AM
Originally Posted by Vasara
then what next? )
Find a well-cared for XJ of the same type, but with low miles, so you can rinse and repeat. Pay the premium for a top notch used one.
ralphwg (06-19-2024)
  #572
Old 06-18-2024, 02:59 PM
Vasara's Avatar
That have been my mind. Local market is pretty much zero available so import from Germany it is again. Offering gets thinner there too.
Noted that one R575 available with low km, 575:s are super rare on EU market. Bit pricey though, 139k Euro.
https://suchen.mobile.de/fahrzeuge/d...24d4629&vc=Car
lotusespritse (06-18-2024)
  #573
Old 06-19-2024, 09:14 AM
ralphwg's Avatar
Received 1,209 Likes on 915 Posts
I have a 2018 575 that i bought in early 2022 fore $90k. Couldnot open link to compare data. Great car!!! Best Jag sedan yet.
  #574
Old 06-19-2024, 10:27 AM
Vasara's Avatar
mobile.de pages are sensitive for almost anything. Seems like currently Edge browser is only one opening pages. Owned by eBay and they working with the issue.
Aaannd.. i made an mistage on link:
https://suchen.mobile.de/fahrzeuge/d...5f579e6&vc=Car
My problem is local import tax for vehicles. For 575 kind of vehicle they add about 30-40% of the value of the vehicle.
  #575
Old 06-19-2024, 02:17 PM
Paldi's Avatar
Default I fixed my driver side door wood trim crack today.
My XJL has a tiny crack under the Meridian logo, down to the bottom edge of the wood trim strip. I purchased a windshield crack repair kit and applied the liquid to the crack
It vanished! See before and after photos plus a picture of the stuff I used.
The crack
Another picture of the crack
What I bought to repair it.
After the repair. I'm happy. I'll put a little wax on it tomorrow, to make it perfect.
The following 5 users liked this post by Paldi:
ralphwg (06-20-2024), RoonieQ (06-22-2024), rothwell (06-19-2024), Stuart S (06-20-2024), Vasara (06-19-2024)
  #576
Old 06-20-2024, 08:41 AM
clubairth1's Avatar
Received 2,351 Likes on 1,851 Posts
Nice repair! Can't see it at all afterwards.
I have always had to send the panels off for refinishing.
Bigg Will
11-28-2018 09:26 AM
scottjh9
07-10-2018 10:29 AM
lossking_
03-23-2017 05:25 PM
heroooo
05-14-2015 10:54 PM
bfsgross
119
05-19-2013 09:38 PM
Quick Reply: What did you do to your X351 today?
