XJ ( X351 ) 2009 - 2019
What is different between 2011 XJ Supercharged and SuperSport?
Old 09-16-2024, 10:49 AM
tergitkerd's Avatar
Default What is different between 2011 XJ Supercharged and SuperSport?
OK, so I know ~ 40 horsepower, but beyond that, I cannot figure out much more of a difference? Is the Supersport a trim-level that has the same motor, but just a different tune than the "regular ol' " supercharged version? I currently have a 2011 XJ L Supercharged but am looking for another one so that one can be a parts donor for the other. I have an opportunity on a SuperSport of the same year, but my research has pulled up nothing of note when it comes to differences. Best I can find is that it is just tuned to XKR spec, but same everything really.
Old 09-16-2024, 11:19 AM
Vasara's Avatar
The Supercharged means only on engine (3.0 SC or 5.0 SC), its not a trim level. Supersport is a trimlevel. (available even with Diesel engine)
Old 09-16-2024, 03:05 PM
XJsss's Avatar
Here is the 2019 brisure as the 2011 was the same. SuperSport had every option except rear seat entertainment screens. Also the SuperSport had 510hp.
File Type: pdf
Old 09-17-2024, 06:35 AM
Jaaag_drivah's Avatar
My 2013 SuperSport has the rear entertainment screens, but not sure if that was an option in the earlier years.
Old 09-17-2024, 07:56 AM
MoscowLeaper's Avatar
Mine 2010 SS LWB had a RSE screens.
Basically SS is 510hp AJ133SC with most of the available options present inside of the vehicle. Somwhere in 2014 SS was replaced with XJR and later was re-introduced as a trim level, but that have nothing in common with the original SS meaning.
Old 09-19-2024, 02:51 PM
XJsss's Avatar
in 2013 they added the rear entertainment as standard equipment and made the advanced cruise control the option. Also the "standard" V8 was 470hp. The SuperSport was the first model in the US that has 510ph.and that was the max power in the XJ until the XJR.
Old 09-19-2024, 03:36 PM
AlexJag's Avatar
Sponsor
Just a reminder , either you have a base 470hp SC 5.0 or top of the line XJR575, hardware is identical and we can easily make your 470hp car go over 600hp with remap alone on the 5.0 SC engines 😆
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
tergitkerd (09-19-2024)
Old 09-19-2024, 09:45 PM
tergitkerd's Avatar
This is exactly what I figured but wanted to be sure. In any event, I ended up getting another 2012 XJL SC fully loaded from the auction. 80k miles. $1600. The one I already have will become this one's parts donor in the future, if ever needed.
Old 09-20-2024, 11:27 AM
XJsss's Avatar
Just an FYI in 2013 the electronics in the XJ changed from Denso To Bosch,
QueenB369
10-04-2022 01:04 PM
d33
09-26-2015 11:02 AM
Pa.Bill
12-22-2013 07:32 AM
AutoMedia
12-15-2010 03:06 PM
hunterjah
09-14-2010 05:24 AM
Quick Reply: What is different between 2011 XJ Supercharged and SuperSport?
