What are you using for Power Steering Fluid on an X351?
Old thread I know!
I never could find that Mobil ATF320. After much research I used Mobil 1 synthetic multi-vehicle ATF. Swapped fluids twice so far and it has worked fine. I pull as much PS fluid out of the reservoir as possible and refill. Not the best but after several rounds you will get most of the fluid changed out.
