What is your choice for an XJL mod, if any?
Location: Mooresville, NC (Race City USA), home of most NASCAR teams.
The frustrating thing about now owning a 2011 XJL is that it is is so perfect from the factory. Yes, I installed splash guards front and rear, and Continental ExtremeContact DWS tires, plus "Jaguar" and "5.0" on the trunk (boot) lid, but would like to hear which most on this Forum would instal next to "upgrade" this beautiful machine: (1) Jaguar Leaper Hood Ornament Emblem, or (2) Stainless steel and rubber brake and accelerator pedal kit, or (3) neither. Vote (1), (2), or (3). Thanks in advance!
Ken Dreger (10-27-2021)
johndahlheimer (01-08-2014)
I did the "Jaguar" and the "5.0" badge updates on my trunk lid for my '12 XJL. I would definitely recommend that. I also have the leaper on my hood, not selected by me but, originally installed by the dealer on the new car. Initially I wanted it removed but, over the past 18 months it kind of grew on me where I actually like it now.
Outside of that, not much available for upgrade. I would love to have different spring rates and a much larger rear sway bar installed but, no one seems to make them.
Albert
Albert
The following 3 users liked this post by axr6:
UPDATE
never mind. I found the thread. It has a larger front bar, not rear. My mistake.
The following 2 users liked this post by another_geek:
johndahlheimer (01-08-2014),
The following 4 users liked this post by Executive:
I installed the plates. OEM parts, did the install myself. Took about 30 minutes. Pretty easy, really.
Now, does anyone know if you can retrofit the illuminated vents to a 2012 XJL S/C? Wondering if the wiring exists.
The following 2 users liked this post by depeche:
johndahlheimer (01-09-2014),
yes, I did my tread plates as well, bought them a few months after the car, I got lucky on ebay and saved quite a lot of money, some of our main Jaguar dealers actually have Ebay shops !
As mentioned above, they took about 1/2 hour. Once you have carefully prised the old ones up you will find an electric plug socket underneath, you simply plug the plug on the underside of the new tread plate into this and re-clip the new plate into place, sorted !
The following 3 users liked this post by roviw:
The lighted door and trunk (boot) sill plates do look cool (like those on my wifes '10 Mustang), and seem like an easy instal, but are a bit pricey, and since the original sills are nearly as attractive, and entry/exit already well illuminated by outside rear view mirror puddle lamps, door mounted lamps, and interior floor level courtesy lamps, I've decided to go with the stainless and rubber pedal covers for $175.00 (including tax and shipping) since the OE all-rubber pedals are really very homely.
Since the engineers at Jaguar designed the suspension around the standard long wheelbase XJ, and I love the way it handles and rides (especially with the Continental ExtremeContact DWS tires which provide superior hydroplaning resistance; snow, ice and wet traction, ride and noise comfort, and less unsprung weight than the original Pirelli P-Zero tires), I'm not about to increase sway bar stiffness nor instal larger wheels with lower cross-section tires, either of which would compromise handling and ride on everyday, less than ideal, roads.
Thanks again for all your inputs!
The following 2 users liked this post by johndahlheimer:
Ken Dreger (10-27-2021),
retriever-007 (01-08-2015)
Would anyone float a price range for the illuminated door sills? .... Never mind, just found it on ebay. YOU GOT TO BE JOKING with these prices.
http://www.ebay.com/itm/NEW-JAGUAR-X...21343482142%26
Albert
The following 2 users liked this post by axr6:
I installed the XJR sway bar and new bushings (the same as the standard SC bushings but wanted new with new) on my SuperSport/Speed and it improved cornering by taking away the wishy/washy transition going into and out of corners and the ride was unchanged. I, also, have the stainless steel exhaust tips. all the other mods being discussed, except the leaper, were "standard" on the SuperSport.
The following 3 users liked this post by XJsss:
The larger rear sway bar would in NO WAY compromise handling. It would definitely produce less body roll, more precise steering and more confident handling. The only single negative to larger sway bars is that they do take away from the independence of the suspension by tying to two sides together. But, since the front factory bar is far larger than the rear its effect is much more pronounced. I always considered the larger rear sway bar to have FAR more advantages than disadvantages. I would install one in a heartbeat if it were available.
Albert
Albert
Thanks for your response. According to your profile you own a 2005 XK8, whereas I own a 2011 XJL, so this being an XJ Forum I really don't know if your preferences are of consequence here. If you prefer a larger rear sway bar than the Jaguar suspension engineers saw fit to provide, then by all means instal one if you can find it. Personally, being a professional engineer myself, I have a great deal of respect for the engineers who developed the suspension on my XJL. It is precise, responsive, and very capable, and doesn't provide any excessive body roll whatsoever, and I have yet to read one professional car reviewer who says otherwise. Personally I don't care for a non-compliant, overly rigid suspension that provides a ride like a grocery store shopping cart, and skitters and darts on rough undulating curves, commonly found on today's entrance and exit ramps, and curvy roads. Peace ,
The following 2 users liked this post by Executive:
I agree, and if the corners had bumps in them, stiffer sway bars would have a negative effect. Stiffer is better in the bedroom, but not in a suspension unless you only drive on nice smooth race tracks and parking lots.
johndahlheimer (01-10-2014)
New Jaguar XJ L Illuminated Tread Plate Set Sill Plates OEM Brand New | eBay
Albert
Albert
I bought from the same guy on ebay, and did an offer of $640... He had them listed back then for $670... I wonder if the price went up since May of last year...
Jaguar New XJ L Illuminated Tread Plate Set Sill Plates Brand New | eBay
johndahlheimer (01-11-2014),
