Will Jag make the AWD xjl in 8 cylinder?
Very true, they had to modify the V6 engine oil pan with the axles going through it in order to maintain the same engine mounting location. The V8 won't be AWD until the chassis is redesigned.
The AJ126 V6 is basically an AJ133 V8 engine that has 2 less cylinders and is made on the same production line as the AJ133. It shares a very similar block as the supercharged V8 AJ133, with some differences such as reduced bore size. Cylinder heads are also derived from the V8 engine. The engine features a balance shaft to drive the oil pump and balance the crankshaft
Received 3,894 Likes
Back in September 2014 when I was in London for the XE Feel event, I was talking with a member of Jaguar and he was saying that not only are they going to have a V8 AWD XJ, but that they were looking at putting a slightly de-tuned version of the supercharged motor into the car (power at 458 hp as I recall vice the normal 470). There is talk about it. When it will come out, hard to say.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
