Window problem
Received 2,194 Likes
Make sure the seals the window rides in are clean and try lubing them with a dry silicone. Then reset the limits of the windows by holding each switch fully up for 5 seconds then drop windows and hold switch down. This resets the electrical resistance reading learned by the door modules. If neither of these works the motor is pulling too many amps and i would replace the regulator and motor assembly
nd4spdlsc
11-26-2019 07:43 PM
Leichardti
09-06-2014 04:35 PM
Jag Pilot
07-04-2013 10:09 AM
