Winter Mode
Winter Mode
I never used winter mode before but I tried it yesterday. If I am correct, this is full-time AWD with a 70/30 split rear to front and it starts in 2nd right? Will it ever change from 70/30? I can actually feel the transfer case engaging when I activate it. I set it at a stop-sign and manually went to first but only did it once so not sure I had an increase, decrease or no change in acceleration.
Has anyone tested out this mode and can comment?
Hello....
I finally used winter mode yesterday. Good for traction but I noticed something odd. My power steering assist dropped way down. It was to the point where I needed two hands to crank the wheel when parking. Switch to dynamic or normal modes restored the power steering assist. Is this a feature or do I have a problem here?
TJ
TJ
Hello....
TJ
TJ
Hello....
TJ
TJ
One other thing to note....earlier in the year I had my BCM replaced. It was a total nightmare that I will save for another post. When I picked up the car, the power steering had very little assist...in all drive modes. When I got it home, SSD said the power steering curve calibration was not performed. I guess the tech forgot to do this after the BCM replacement! The power reach and rake of the steering wheel did not work either. I ran both the wheel and power steering calibration functions and everything started working...so I thought. Seems like just winter mode is effected.
Any thoughts are appreciated!
TJ
TJ
