XJ ( X351 ) 2009 - 2019
X351 2012 XJL Best choice of new headlamp bulbs
Old 06-12-2024 | 09:59 AM
GreenGator71's Avatar
Default X351 2012 XJL Best choice of new headlamp bulbs
I need to change my headlamps on my 2012 XJL. The y are the original and night time driving is not the best. My question to you all is what is the best bulb to replace with that will help with better night time visability?
I watched a video where a person that owned a 2011 XJ used Mars Auto 600K HID.
Looking for advice on your success with headlamp bulbs.
JD
Old 06-12-2024 | 11:33 AM
Vasara's Avatar
Ohhh.. 2012 and you have original headlight bulbs? They must be like candles now.
Since it is quite big operation to change headlight bulbs i would only use good brand, because you don´t want to repeat the job in just few weeks. Its bit a task in first time, but for next time its not so bad when you know where to look for screws. (you need to jack front up, but not nessesary to remove wheels. Just turn them away while working each side to remove bumber cover.
I have been changed bulbs few times on my 2010 and i used these:
https://www.osram.com/ecat/XENARC%20...4/ZMP_4063569/
Every time i have been changed bulbs there have been big differense on lights. For next time i need to clean the lenses inside too somehow. (not sure if the projector pack will come out thru service lid of the light assembly? Have anybody done this?)
Old 06-12-2024 | 11:47 AM
The taking apart is not a worry as I had to do some work on the inner fender liners and saw the screws plus I watched a video that was very clear on what to do. However, you are right, dont want to go back in within a month.
Thank you for the information. I used Osram on my Town Car and they were very good lamps. Lot easier to remove those lamps.
I just looked them up on Amazon and oh boy, $199 for 1 bulb, does that sound right?
JD
Old 06-12-2024 | 01:49 PM
Vasara's Avatar
Check again if you spot dual pack, because should be less than $100 for pcs.
Old 06-12-2024 | 02:31 PM
I did relook and found it, thank you.
Looking forward to adding them this weekend.
JD
Old 06-12-2024 | 03:11 PM
12jagmark's Avatar
Have you checked Rock Auto?
IIRC Osram and Wagner are the same brand, and they're $80 each. I'd guess Hella might be the originals and they're $47 each.
GreenGator71 (06-12-2024)
Old 06-15-2024 | 01:35 PM
RoonieQ's Avatar
I have to replace my old original bulbs too and notice that the lenses also need a good wipe.
Old 06-15-2024 | 04:34 PM
12jagmark's Avatar
Good point - over time they do get a cloudy residue inside for some reason. That reduces brightness too, probably as much as an aging bulb.
I use forceps to hold a cloth that'll fit in there to wipe it off.
RoonieQ (06-16-2024)
jschimmels
07-09-2022 04:21 PM
JordanXJL
09-07-2021 08:29 AM
convincor
02-14-2021 02:53 PM
LETAP007
01-18-2011 02:00 PM
Quick Reply: X351 2012 XJL Best choice of new headlamp bulbs
