XJ ( X351 ) 2009 - 2019
X351 Power Steering Fluid
Old 08-03-2019 | 05:58 PM
mikebaker3's Avatar
Default X351 Power Steering Fluid
I noticed that the power steering fluid level was close to the minimum mark on my 2014 XJ Supercharged. Owners manual specifies Mobil ATF320 PAS Fluid. I have been to Auto Zone and O'Reileys but have not been able to find any. What is everyone using stateside for the fluid?
Old 08-04-2019 | 08:20 AM
Thermo's Avatar
mikebaker3, I used the Pennzoil "European" fluid in my car when I had a hose that was going bad. Worked just fine. There is also a "Japanese" fluid out there that is essentially the same stuff. Both are a full synthetic fluid. I have had the European fluid in my car for the last 30K miles with no issues. Please keep in mind that my car is a 2012 and maybe the fluid has been updated over the years. Though, looking, it has been the Mobil ATF320 from 2010 to 2014 at a minimum. I found the Pennzoil fluid at Walmart and all auto parts places.
mikebaker3 (08-04-2019)
Old 08-04-2019 | 10:30 AM
mikebaker3's Avatar
I downloaded the attached specification sheet on the Mobil ATF 320, which seems to be only in the European market. I will check the specifications listed on the Fact Sheet against the Penzoil to see if listed.
Thanks to Thermo for his experiences using the Penzoil.
File Type: pdf
Old 08-04-2019 | 03:15 PM
mikebaker3's Avatar
So, I went to Walmart, but found no Pennzoil. Likewise none at O'Reilly or Autozone. Autozone had a Prestone European Power Steering Fluid that the label claimed was compatible with Jaguar. Autozone had a Mobil 1 ATF, but the specs were not listed as complying with any on the list in the Mobil ATF 320 Fact Sheet. Autozone had that fluid and this Mobil1 Synthetic ATF Multi-Vehicle Formula. The bottle is darker gray than the Mobil 1 at Autozone. Advance Auto had both sitting side by side. This fluid lists three of the specifications on the label that are listed on the Fact Sheet. So, I bought this $10.99 per quart plus tax.
Old 08-04-2019 | 03:19 PM
mikebaker3's Avatar
It was Advance Auto that had both Mobil 1 ATFs, not Autozone. Autozone only had the lighter gray bottle version.
JaromirJaguar11
09-10-2018 10:02 AM
arkmark
04-05-2018 11:56 AM
BKSinAZ
02-21-2015 03:02 AM
sunchip
01-28-2015 09:21 AM
MarcB
01-16-2012 11:29 AM
Quick Reply: X351 Power Steering Fluid
