XJ 351 Rear sun Roof blind switch not working
NMW (12-19-2019)
thank you
If the rear sun roof still works from the front switch then I’d probably investigate the rear switch. First, you should disconnect it and then reconnect it to see if it functions properly. There’s a chance that it will. If it doesn’t, I’d look on eBay for a used switch. You can find one anywhere from $40 to $80. It’s not too difficult to swap out them out. If I remember correctly, it can be carefully pulled out, then remove the connectors. Either way, my guess is that the problem is fixable spending very little money. Hope this helps.
thank you for the email i will try what you have recommended, fingers crossed -
Mark
