XJ 5.0 Supercharged Brake Squeal on First Bite
5.0 supercharged (the larger brakes). I have tried:
New rotors
New pads (change from semi metallic to ceramic)
Lots of brake lubricant on both slide pins and backs of pads
I get an obnoxious squeal on light pressure when braking >40mph-0mph. Left front only. Increased pressure stops the squeal.
Anything else I can try before replacing the caliper?
New rotors
When I bought the car, the dealer put all new oem pads and rotors on the car. So for me, it always had a left front squeal on first bite (usually after warmed up)
I put ceramic Brembo pads on all the way around as I was so tired of the insane amount of dust from the oem semi metallic. The squeal seemed to temporarily go away, but now it is as bad as ever.
afransella
03-26-2019 03:43 AM
