XJL 2011 slow coolant leak
https://www.jaguarforums.com/forum/x...oolant-193660/
My bet. Rear crossover pipe. My 2011 XJ started leaking there at 80k miles. Slow leak with a slight smell of coolant. I complained of a coolant smell and the dealer couldn’t find it, but my independent did. A month after my CPO warranty expired.
The rear crossover pipe is located at the very back of the engine. It connects both heads with coolant. You will need to remove the engine intake manifold to get to it. Major pain, but much cheaper than a new motor. Put the car on a lift and remove the bottom aero pans. Use a flashlight and look for coolant stains on top of the transmission dripping down.
#28
I had the same issue I replaced my water pump and thermostat 2 times cause I couldn't figure out the issue turns out it was the Y pipe under the intake manifold and the rear crossover pipe labor and install at the dealer i paid 1500 bucks
bad design cause the pipes are made of plastic
2011 XJ 5.0na
Sentinelist
08-26-2013 09:37 PM
