XJL 2013 AC not cooling while car is idle
What checks have you had done ? Normally, an air con technician will check the refrigerant quantity in the system. This is done by evacuating and then weighing it. I suspect you're down on the amount required. The climate control system on these cars normally gives very little trouble, but some people turn off the air con part of it to "save money" and then end up with a duff compressor costing hundreds of pounds/dollars to replace. Some saving !!
Take a look at this post as I had the same issue and replacing the valve that I had was the problem. My AC now cools at idle. https://www.jaguarforums.com/forum/x...ciated-206120/
Kyng Kyle Chestnut
04-19-2018 04:04 PM
Alex Martinez
19
02-28-2018 02:14 PM
Executive
06-26-2013 10:22 AM
monchie313
10-22-2011 08:00 AM
