XJL Air Conditioning
Same thing I was thinking when he described his symptom. Unless set to sync, the driver and passenger side temperatures are adjusted separately. Now if they are set for sync and/or he adjusted the passenger side down to a cold temperature and it still blows hot, this isn't a problem with the compressor etc.(otherwise he would get no cold air anywhere). but more than likely either a stuck flap that is staying in the position to bring in air from the heater core, or the climate control module not sending the signal to put that flap into the correct position.
axr6
08-01-2013 03:00 AM
axr6
07-19-2013 06:19 PM
