XJ ( X351 ) 2009 - 2019
XJL - A/C, volume and door locks not working
Old 06-16-2022, 02:59 PM
leaddog11's Avatar
Originally Posted by Greg Wojdalski
Update: I got the new panel, hooked it up, but still nothing worked. Actually, I started getting all sorts of warnings on the dash, including key fob not found. This is probably because the new panel is from a 2017 model with different button configuration. But, I then hooked up the old panel again and worked all the buttons and after playing with the fan control, the panel started working.😀. So, for now everything is back to normal and everything works as it should. Let’s see for how long.
great
  #42
Old 12-07-2022, 10:00 AM
selojoe's Avatar
Default Need help
You were lucky, as that's an easy fix. The fuse box was the first thing I checked, but all fused were in order in my Jag. I am convinced it was a spilled drink that caused a short of some sort. My panel is working just fine for now, but I wouldn't be surprised if it malfunctioned again at some point in time.
What's the fuse number?
  #43
Old 12-07-2022, 10:05 AM
selojoe's Avatar
Default Fuse
Thanks Dercur but can you give us what fuse number it was?
Did you find out what fuse it was
  #44
Old 10-14-2023, 09:34 AM
clubairth1's Avatar
Received 2,426 Likes on 1,906 Posts
No he never came back to tell us??
Hailers
02-26-2018 09:16 AM
Fairlane500
12-09-2016 10:27 PM
amcdonal86
03-01-2016 01:28 PM
jimbov8
01-27-2015 08:32 PM
Richy_T
12-23-2011 05:38 PM
Quick Reply: XJL - A/C, volume and door locks not working
