XJL - A/C, volume and door locks not working
#41
Update: I got the new panel, hooked it up, but still nothing worked. Actually, I started getting all sorts of warnings on the dash, including key fob not found. This is probably because the new panel is from a 2017 model with different button configuration. But, I then hooked up the old panel again and worked all the buttons and after playing with the fan control, the panel started working.😀. So, for now everything is back to normal and everything works as it should. Let’s see for how long.
#42
Need help
You were lucky, as that's an easy fix. The fuse box was the first thing I checked, but all fused were in order in my Jag. I am convinced it was a spilled drink that caused a short of some sort. My panel is working just fine for now, but I wouldn't be surprised if it malfunctioned again at some point in time.
#44
