XJL Lowering Solution?
kinda back from the dead here....are the Supersports and XJ-Rs not lower than the others? It seems odd that a 3.0 diesel and an XJR would have the same ride height, but stranger things have happened.
If they are in fact lower, we could use the XJR setup in our cars, which i assume is stiffer and lower front springs and a setting for the rear air suspension.
Edit - at least one member had it done custom: https://www.jaguarforums.com/forum/xj-x351-53/modded-xjl-116939/
