XJ ( X351 ) 2009 - 2019
is yellow fuel cap norm for the xj?
Old 02-05-2018, 06:04 PM
gochurush's Avatar
Default is yellow fuel cap norm for the xj?
Didn't think too much of it when I got the car but now I must know...
e85 and reg gas for xj?
Old 02-05-2018, 06:36 PM
XJsss's Avatar
Doesn't look my my OEM cap and I do believe that these XJs are not E85 compatible. Plus my cap has a tether but you are in California and who knows?
Old 02-05-2018, 07:45 PM
rhomanski's Avatar
My 2012 5.0l supercharged says 10% ethanol max if you absolutely have no choice and premium only. My GM's always said you could use mid grade with reduced performance when the knock sensor goes off. There was no ethanol at the time they were made I don't think.
As far as the color, I don't know, it came with a full tank and it's still at half.
Old 02-05-2018, 08:01 PM
Stuart S's Avatar
Received 6,426 Likes on 3,514 Posts
The filler door sticker is in English and French. Canadian car, perhaps?
Old 02-06-2018, 09:23 AM
carzaddict's Avatar
definitely not OEM. my car is a canadian spec and does not have a yellow cap
Old 02-06-2018, 09:33 AM
Received 2,266 Likes on 1,845 Posts
+1, nor is any Jag approved to run on E85. Correct fuel is 91 octane AKI.
Old 02-06-2018, 09:53 AM
Stevie7's Avatar
I have a yellow cap, but mine is diesel ��
Old 02-06-2018, 12:55 PM
Leo032's Avatar
Owner's manual for my SS specifically says not to use gasoline with more than 15% ethanol content.
Old 02-06-2018, 01:35 PM
XJ8JR's Avatar
I'm in SoCal and I have the same cap. Probably some California bs.
gochurush (02-06-2018)
Old 02-06-2018, 02:32 PM
roviw's Avatar
Mine is a diesel UK car and the filler cap is yellow
Old 02-06-2018, 08:33 PM
Stuart S's Avatar
But does it say "E85/Gasoline"? Not for a diesel.
Old 02-06-2018, 08:57 PM
What does it say about fuel type?
Old 02-07-2018, 12:01 PM
roviw's Avatar
No mine just says Diesel, I thought the original poster was expressing his surprise at seeing a "yellow" cap as opposed to a black one.
Old 02-07-2018, 01:01 PM
rhankey's Avatar
I wasn't personally aware Jag had any E85 offerings, but here's a government website that suggests there might be a flex-fuel version of the XJ referred to as "XJ FFV":
https://www.fueleconomy.gov/feg/noframes/35229.shtml
And here's a link offering XJ 5.0SC FFV used replacement engines:
https://www.buyusedengine.com/used_e...%208th%20digit)
Nothing mentioned on Jag's US website. Perhaps some California dealers are special ordering the FFV version.
gochurush (02-07-2018)
Old 02-07-2018, 02:41 PM
gochurush's Avatar
For gasoline cars, yellow cap usually means it can use e85. (well at least in CA)
So yeah in a way I was surprise the XJ can take e85 from the factory... Not that I will ever use e85.
Old 02-07-2018, 02:56 PM
Richxk8's Avatar
Just picked up a 2014 XJL, has the yellow cap and specifies High Test Gasoline or E85. It is the 3.0L supercharged V6.
Old 02-07-2018, 03:25 PM
XJ8JR's Avatar
I'll have to double-check, but I do recall seeing the term "Flex-Fuel" on my CarFax reports or somewhere.
Old 02-07-2018, 03:33 PM
Received 6,361 Likes on 5,534 Posts
According to Wikipedia (yes I know) these can all use it.....
XF 3.0L 2014 XF 5.0L 2013- XJ 3.0L 2013- XJ 5.0L 2013- Range Rover 3.0L 2014 Range Rover 5.0L 2014- Range Rover Sport 3.0L 2014 Range Rover Sport 5.0L 2014-
Mikey (02-07-2018)
Old 02-07-2018, 05:37 PM
XJsss's Avatar
If I want corn alcohol I'll either drink Tito's or moonshine, but my baby will never see it!
Old 02-11-2018, 09:02 PM
niceguy753's Avatar
Default Flex Fuel Premium
My 2014 XJL has a yellow flex fuel cap. It does state in the fuel filler area to USE PREMIUM FUEL ONLY....so is there
Premium FLEX FUEL?
Quick Reply: is yellow fuel cap norm for the xj?
