Backlighting on dash switching off even with the main beam on
A bit if a strange one, I took the Daimler out for a drive in the evening for the first time in some months, and when I turned the lights on, the dash backlight came on for a few seconds, then turned off. Without it, you can’t see the speedometer at night. The behaviour was repeatable, turning the lights on means the backlight turns on, but after a few seconds, it switches off again. Any ideas on where to start with this one?
Parker 7 (04-01-2023)
Switching to over ride will bypass the dimming resistor (and going back into the dimmer module ) and be full bright
The next step would be the grounds
If more that one section of lights beyond the instrument cluster are effected it could help narrow it down
Stereo head ?
Climate control panel ?
See page 123 or 125 for long wheel base model
www.jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Stereo head ?
![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
Tried to do a bit of fault finding this evening, but everything was working fine. At least if it does it again I’ll know to look at the dimmer switch (which embarrassingly I didn’t even know was a thing).
Thanks for your help, I’ll post again here if it happens again, and how it gets resolved.
Parker 7 (04-02-2023)
Kevin richradson
07-26-2021 10:51 AM
