Front Suspension Bushing Orientation
I guess this is the only photo I have of my car side-on with the 20-spokes on. The lower door shutline intersects just above the axle centerline. The rear is too low here, IMO, as there's a slight negative rake. I've since added 6mm* packers, new foam donuts, and lower spring isolators, bringing the rear up about an inch.
* The car came with a 6mm packer in each upper rear spring pan. Each side now has two.
watto700 (09-23-2024)
Thank you for looking for ride height info!
Progress slowed slightly today when I found standard size fitting on driver side brake pipe and metric on the other! Fedhill.com to rescue again, it should all be M-10 1.0 all around. They’d just smashed it down on a metric hose. Jam nut was standard too…. And pretty well jammed… just on drivers side. Weird.
knowit
07-01-2024 06:10 AM
mhamilton
09-22-2014 06:32 AM
