Having instrument light problems
Hey guys,
I own a 1995 XJ6, the car runs perfectly but the check engine light, transmission light and gas light are all stuck on. I tried reseting the system by pulling out fuse 12 in the back left fuze box and letting the car idle for a few minutes before putting it back. It didn't help. Also, my gas gauge isn't working, it works intermittently depending on the outside temp. Any insight would help.
Hey guys,
The CEL has to be reset with a scantool. Pulling fuses doesn't clear it.
Given the additional issues, I'd suggest you have the codes read and post any stored or pending codes on the forum for an explanation of what they mean. Post the actual codes as the precise interpretation can vary between model and year.
YacobX (05-26-2012)
99xk8guy
06-05-2023 06:28 AM
