XJ XJ12 ( X305 ) 1995 - 1997
Help key will turn on but stuck in ignition
Old 12-25-2014 | 08:41 AM
bmorenmiami's Avatar
Default Help key will turn on but stuck in ignition
i have a 1996 vdp just got it running great ...bought from auction it came with two keys...i used the green one for ignition...worked fine in and out...i also received a black one which i used for the doors ...i mistakenly put that one in ignition and voila stuck! what do i do.
Old 12-25-2014 | 01:32 PM
gatekeeper's Avatar
Not sure, but try disconnecting the battery. If it comes out good. If not try jiggling the steering wheel while doing the same with the key and trying to pull it out at the same time. Things to try that won't hurt anything. Let us know if it comes out or you need more options.
JarodL
03-07-2024 02:39 AM
dsnyder586
04-04-2019 03:38 PM
XJsc-guy
11-23-2015 02:56 PM
avern1
09-08-2015 07:25 PM
Sprayall
09-03-2015 08:49 PM
Quick Reply: Help key will turn on but stuck in ignition
