Transmission Query
Old 12-04-2016, 02:54 PM
Pier Paolo's Avatar
Default Transmission Query
I located in Italy a Jag xjr v8 - year 1999 - and wish to buy it from the present private
Owner.
While testing the car I noticed that the gearbox lever cannot be moved from P position unless pushing several times the brake pedal.
Can anybody give his advise about this fact? tks
Old 12-05-2016, 05:21 PM
ericjansen's Avatar
Received 1,353 Likes on 927 Posts
Owner.
There is a brake switch (located in the well, fitted next to the brake pedal assembly) and a solenoid (located in the gear shift housing).
Both of them can be at fault.
If the contact is on, and you push the brake pedal, you should hear a click at the gear shifter, which is the solenoid releasing the shifter to move.
There could be several reasons if one of the 2 is not working properly.
Do the brake lights come on?
Old 12-05-2016, 06:57 PM
RJ237's Avatar
Received 2,812 Likes on 2,242 Posts
+1 Eric. Almost certainly the brake switch.
vdpnyc
12-09-2016 06:37 PM
McJag222
11-09-2016 09:43 PM
Gopi Hira
11-09-2016 02:30 PM
sososs
XJ40 ( XJ81 )
11-07-2016 04:22 PM
kesslari
11-07-2016 02:00 PM
Quick Reply: Transmission Query
