window motor
You can take the one you have and run it fwd and back with a battery charger
Just flip wire connection to run other way
This even works on car , just pull the 2 heavy wires out at the fwd of the door panel and clip
This will be high current so arcing hazard , the motor has resistance so not a direct short of the charger
Put the charger on 10 amp setting and not lower to run properly but you can use the lower than to practice the connection to be made
There is a thing of the charger being higher voltage than a fully charged battery ( 12.75 ) which does give the motor more electromotive force to move an otherwise not moving motor on regular battery / alternator voltage 13.5 - 14.5 )
There is a procedure on final installation of the motor that the controller knows full up
on full up window position continue to hold button up for a few seconds
Worked for me
Regulator lubing ?
When you put connector back on the door controller , ensure the pins lock in place as this was my issue of motor not running , motor was just fine so first step
The pins migrate away from connection
Worked for me
Regulator lubing ?
