Wrecking yard rarities
G’day Jags,
I have replaced my radiator from above and without removing the bonnet/hood. The empty radiator is not that heavy.
Remove the fan shroud and the radiator fan first and you’ll have plenty of room. The condenser is not an issue.
I repaired a small leak in a radiator once with a blob of JB weld and it lasted for years until I replaced that radiator when the plastic hose spigots started to disintegrate.
Cheers,
Jeff.
Cheers,
Jeff.
The following 2 users liked this post by watto700:
olivermarks (03-31-2024),
Parker 7 (03-31-2024)
G'day Oliver,
They both look very similar on here https://parts.jaguarlandroverclassic...-jaguar-parts/ and the only difference in the relative part numbers is the suffix. Maybe a late model XJ40 radiator is suitable.
Cheers,
Jeff.
Cheers,
Jeff.
olivermarks (04-03-2024)
olivermarks (04-04-2024)
The following 3 users liked this post by olivermarks:
#28
olivermarks (04-08-2024)
rhofatl
04-21-2017 12:18 PM
SamOscarBrown
01-01-2014 12:41 PM
