2003 X-TYPE High Beam Light Problem
Welcome to the forum dmanjar60,
Good to have you here with us at Jaguar forums. That sounds like a dip switch issue but I've copied your question to X-Type section for advice from members with the same model as you have. Here's the link to the thread:
https://www.jaguarforums.com/forum/x...roblem-102018/
Follow this link X-Type - Jaguar Forums - Jaguar Enthusiasts Forum to the main X-Type section for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the US Southwest Region section by following this link https://www.jaguarforums.com/forum/southwest-us-az-tx-nm-ok-37/ to find other members in your region.
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
In the meantime, any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link
Helpful_information
See you in the forums....
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
