@006 Jaguar XJR hesitates around 2,000-3,000 Rpm
Old 09-02-2010, 10:08 AM
XJRPro's Avatar
Exclamation @006 Jaguar XJR hesitates around 2,000-3,000 Rpm
My Xjr went into Restricted Performance when I took it on the highway. The engine has trouble getting pass 3k then it suddenly shoots to 4K Rpm and seems like there is no power that RP Mode comes on. I kept up on my oil changes and main. I don't know how this happen any help will be appreciated
Old 09-02-2010, 01:33 PM
user 2029223's Avatar
Banned
Have you checked for thrown codes? My gut says induction system, maf, air cleaner, leaks,etc. Then oxygen sensors. But there should be a code thrown somewhere here.
Old 09-03-2010, 09:33 PM
XJRPro's Avatar
Exclamation Now the car has a dramatic lose of Horse Power
I believe it has a vacumm leak somewhere it also sound like a ratling noise if I try to get on it on the highway saw a cam code on the ob2 says the mechanic ... This is really weird changed my oil religiously .. Where should I start ???
Old 09-04-2010, 01:33 AM
djdex's Avatar
You need to know what that OBD code was and from there, what it means, find that number and post it back here.
Old 09-04-2010, 04:02 PM
XJRPro's Avatar
Exclamation Here are the Codes I wrote down from the OB2 Scanner
PO430- Catalyst Efficiency Below Threshold (Bank 2)
PO420- Catalyst Efficiency Below Threshold (Bank 1)
PO316
PO300
PO308
PO307 } Basically Ever Cylinder Had Missed Fired
PO306
PO305
PO304
PO303
PO302
PO301
PO101 Mass Air Flow or VAF A CKT Rango / Perf
It sounds like a hissing sound over top of the motor
Maybe a Vacuum Leak and Bad Oxygen Sensor
The Car hesitates when I try to accelerate after 10 minutes of driven
Then Restricted Performance
Do you know where I should Start?
Old 09-04-2010, 05:48 PM
Fraser Mitchell's Avatar
Received 2,450 Likes on 1,948 Posts
Possible split hose that is connected to the inlet manifold thus letting extra air into the engine thus bypassing the air flow meter, and confusing the ECU.
Old 09-11-2010, 11:58 PM
XJRPro's Avatar
Exclamation Ether Test
I tried using Ether by spraying the motor to find the vacuum leak on the intake.
No Progress with that
Do you happen to know any techniques of finding that leak another way??
BrentGardner
28
04-26-2024 03:08 AM
Drew2006
11-24-2015 11:14 AM
97xj6lucy
09-03-2015 07:44 AM
BlacXJRcat
08-28-2015 07:10 AM
Zues
08-27-2015 12:02 AM
Quick Reply: @006 Jaguar XJR hesitates around 2,000-3,000 Rpm
