02 sensors reading low, no CEL
I am troubleshooting a 2005 Jaguar XJ8 Vanden Plas with the 4.2l V8. I am getting low voltage readings on both banks but do not have a check engine light, no codes stored, etc. I am trying to get this car smogged after sitting for a few years and am at a loss. I recently replaced the MAF sensor with an aftermarket unit and replaced all 8 coil packs and spark plugs. This vehicle has a badly damaged airbox that has most of the clips broken off. I seal it with a tie-down strap. I also recently changed the PCV valve assembly.
At this point, I have tried to get this vehicle smogged three times and keep getting fails for lean condition, but I can't find any air leaks. I've checked the hoses to the PCV and air inlet. I am hoping that someone might be able to clue me into where to look next. Thanks
