04 4.2 Supercharger Question
Major Question: Can I put a 2004 factory supercharger on a non supercharged 2004 4.2 motor???
My 2004 XJR supercharged 4.2 engine is bad, I have a spare 2004 non supercharged 4.2 engine is why I am asking.
I know about the variable camshaft timing, I can switch the cams, sprockets and chains etc.
By the time you have swapped 8 pistons, (rings, gudgeon pins, rod bearings... yadda yadda,,,) you'd probably be just as well-off to rebuild your supercharged motor - or another one like it.
You could also simply forgo the blower.
The NA 4.2 has better 'real world' performance (not 'racing') as a daily-driver anyway.
- Less 'total' power at peak, but faster response off the line and in medium speed commuter-trafffic sword fights.
1000% wrong. The whole point of a roots blower is immediate torque. The supercharged engine is better at every vehicle and engine speed and it's not even close
Pete M (09-13-2024)
The Supercharger maker has done a good job. JLR has integrated it well. Mostly if "JFW" with relatively little extra maintenance need nor expense.
I've no quarell with it.
That said, neither is is magical, free money, or better sex.
For most daily-driver situations NEITHER an "NA" nor "blown" AJ Vee engine is asked for but a small fraction of available power.
WHEN in that majority-of-the-time 'range' - 'ordinary' driving, dictated by traffic, road conditions, weather, and other drivers - the normally aspirated AJ Vee is a skosh more responsive.
BOTH are limited by electronics to a top speed about DOUBLE the legal maximums in either case.
That's not "theory", lab tests, racing, hill climbs, 'alone on the road to go and PLAY'.. or wishing, hoping, day-dreaming about any or all of the above... plus better sex, and free money, whilst we are wishing.
It's just how they are when operated in amongst the usual external constraints.
Marine or aircraft recips? Long hours at steady power - altitude gradient? Dif'rent story.
Engine-driven plus exhaust driven for "Turbo Compounding" if you please.
Drinkin' too much advertising hype kool-aid, Pilgrim.
Make parts and upkeep a tad cheaper for the easier to service NA's I prefer.. more especially with RWD "only" vehicles on snow and ice..
Darrol2004
09-10-2024 09:20 AM
These darn cats
09-04-2016 05:25 AM
