04 VDP Suspension
04 VDP Suspension
Replaced upper control arms and removed struts, put it all back together and the air struts will not raise up. All fuses are good, R1 relay (engine compartment) is good, reset the computer and still nothing. The only problem I can find is, there is no power going to the compressor. That is, I used a volt meter and unplugged the connector to the compressor and I get zero reading on the volt meter (and yes i checked to make sure my volt meter was working properly). Any Ideas?
driver safz
09-26-2015 06:01 AM
