04 xj8 at auction, cats system fault, confused with codes
Normally my go point scanner pulls body codes and ect but it showed no codes with all the monitors set. I hooked up the sdd to check codes and came up with these permanent dtc:
U1262
P1672
There was more historic, temp, intermittent dtc set but I'm assuming the permanent dtc are causing the light to come on.
Any tips? I wonder if some one caused the code to come on when it was siting on the auction lot
U1262
P1672
rachelstr
09-03-2015 12:59 PM
