'04 XJ8 Backup Beeper Inoperative
It was working fine but not now. No audio at all when backing and close to an object. Dealer seems to think the speaker or whatever it is that makes the beeping sound needs to be replaced. If so, can someone advise how to do that, and most of all if this sounds like what is wrong. Thanks.
Jim
Jim
Switch ignition to position 2 and the gear lever in R. (engine off)
Put your ear close to every sensor and listen for a clicking sound.
The system is controlled by a parking sensor module which is on LHS (maybe RHS in US) of
the spare wheel well.Check that this is not wet and connections are good
also check for water at bottom of wheel well.The speaker is located under the rear parcel shelf and it's a reasonable assumption that it has
failed but it can be tested at the rear lamp wiring without accessing the speaker itself.
A diagram often helps.
The speaker (item2) is plugged into to the module (item1) in the luggage compartment - see the circled area:
Check this connection and follow the harness to the speaker. If you're very lucky, it may be accessible from behind the trim.
