04 Xj8 Need New Head
They would weld the surface to build up material and then resurface it down smooth. Not sure on the price though. But it may be worth looking into.
Thanks guys. Definitely looking into that. Found a place to pressure test and resurface for $120 each head. Although now with all the parts I'm replacing im considering replacing the whole engine for like $1200. Buying all the parts I want to replace new is coming to be like $2000. Decisions decisions. Whole engine would be cheaper but it'd be all used parts again. New parts is nice but more expensive.
..... with all the parts I'm replacing im considering replacing the whole engine for like $1200. Buying all the parts I want to replace new is coming to be like $2000. Decisions decisions. Whole engine would be cheaper but it'd be all used parts again. New parts is nice but more expensive.
However, the factor that tips the balance for me is how susceptible the Jaguar V8 is to warped heads from overheating. You can't be sure of the provenance of a used engine unless it comes out of an accident write off with a previously perfect service record! You could easily be buying someone else's trouble and, even if it comes with a warranty, switching engines a second time is no fun.
Painful though it is to spend the extra, I'd go the new parts route which draws a line under the issue.
I am curious how a head gets cavitation to that level. You didn't state how many miles, but off an 04 it likely is a fair amount. So... not running the Jaguar OAT coolant or changing it as required? I think the orangeaid is good for 5 years, but it does cause me to wonder what my internals look like (and the cars as well!) I am not the best with coolant service but I always run the right stuff, never mix types and will change out coolant that looks obviously nasty. That pic has me wanting to go flush it right now!
judaji
09-14-2019 12:24 AM
