04 xj8 Transmission Fill plug leak?
Good day,
Gave my transmission a new pan, sleeve, lgf6 fluid.
Did it per spec getting to 40*C and filling till dripping out.
I noticed the fill plug is leaking some coolant overnight. I tightened it up some more, checked back the next morning, still the leak. Anyone every experience this?
Was considering putting the plumbers tape on it to snug up the threads. I really don't want to go through the refill procedure again. Figured I could jack car up on passenger side so fluid in trans is away from fill plug and give it a go.
Thoughts?
Thanks!
Thoughts?
Thanks!
Don B (03-01-2019)
Good day,
Thoughts?
Thanks!
Thoughts?
Thanks!
Don B (03-01-2019)
Received 12,949 Likes
If your exhaust pipe runs as close to the transmission as the ones on all the X350s I've serviced, you don't have room for a torque wrench, so I just use my cut-down 8mm Allen wrench to make the plug as tight as I can by hand. The torque spec is 35 Nm / 26 ft. lbs. +/- 10%, so if you're using an Allen wrench about 6 inches long, you can put 50 pounds of tension on the end of it, which is all many of us can manage while lying on our backs under a Jaguar.
If you're sure the plug is really tight but still leaking, your idea of jacking up the passenger side so the fluid will flow away from the fill plug should work. If the plug does have an O-ring, you may be able to find a suitable replacement at an auto parts store (it will be metric in both cross-section and inside diameter (I.D.)). If there is no O-ring, clean the area around the fill hole and clean the plug to be sure no grit is preventing the plug from seating properly.
If the plug just won't seal, while I can't argue with abonano's recommendation that you get a new plug, you may be able to resolve the issue by cleaning the threads on the plug and in the fill hole and applying a small amount of a suitable sealant to the threads. There is almost no fluid pressure at the fill plug, so any good pliable oil- and temperature-resistant sealant should work, such as Permatex Thread Sealant (either the High Temperature or High Performance version), Permatex Ultra Black RTV silicone sealant, etc. All are available at most auto parts stores. I would avoid thread lockers (Loctite) or rigid sealants like Permatex Ultra Grey, which could make future removal of the fill plug even more difficult than it usually is. Use a very small amount of sealant all the way around the last few threads near the head of the plug, but none near the threads at the leading end. You want to avoid the possibility of any sealant squeezing off the end of the drain plug into the transmission, where it could harden into a glob, break off into the transmission and work its way into the valve body where it could cause a serious malfunction.
To clean the fill plug, use any zero-residue solvent like brake cleaner, electronic cleaner, MAFS cleaner, acetone, lacquer thinner, etc. and allow to dry. To clean the threads in the fill hole, apply solvent to Q-tip swabs/cotton buds and carefully clean the threads repeatedly, then follow up with dry swabs/buds until they come away clean. Take care to leave no fibers behind.
Cheers,
Don
Thanks guys,
I put an o ring on it from the auto parts store. One of those red/Help! Ones that I had lying around, it fit well. The bolt has a shoulder for the o ring to seat onto.
I also have old copper o rings from my turbo days. Some did leak out during this procedure, but I’m not concerned as I had filled it a tad extra, it was leaking a decent sized stream at 40*c
Let’s see if this works!
Thanks again!
Thanks again!
Don B (03-02-2019)
I looked further there is a green oem rubber o ring on the plug. I replaced mine with a copper turbo coolant line feed from a past car, I annealed the copper washer so it was reuseble. Now if I can only get the pan to seal, torqued to spec in sequence with a new pan/gasket did not fix. Added Toyota fipg to the gasket let it dry overnight refilled this morning and monitoring.
the green o ring crushes once it is used once. the directions for changing transmission fluid say to use a new fill plug. i looked at my old one and the new one, and it was clear that the thin green o ring squishes down once it is used. maybe someone can use a thicker o ring? the fill plugs are only $7-8 from the dealer, or $4 ish from zf (fcp euro, ctsc, etc) so maybe thats worthwhile doing rather than a thicker o ring?
with the car off, i think lifting the passenger side by itself, probably won't be enough because its 1-1.5 quarts in the transmission over the fill plug when the car is level. you probably will need to lift the passenger side, get your fill plug ready and tools set up, then have someone else turn on the car and right away change the fill plug (so the exhaust doesnt get too hot and burn you). if you do it within 1-2 minutes of the car being on, it shouldnt get too hot.
I don't understand the concern people have for burning themselves on the exhaust, I found it very easy to get under that with the car on ramps and do the fluid/change fill. I guess I am skinnier than most haha
Cheers,
Don
jackra_1
12-09-2016 01:22 AM
