04 xj8 won't stay running
Old 10-13-2017, 04:00 PM
skim7443's Avatar
Originally Posted by thomash85715
The jaguar dealer in las vegas sells parts cheaper via the web than my local dealer does over the counter, usually by 20% or so. Even with shipping the advantage is worth it. Once you get a jaguar part number for your pump, you might be able to cross reference to ford. Maybe Lincoln LS uses same one? I did find ford parts for my X-type that matched and were less money. I have gone back over this thread and do not see the part about misfire codes. Are you saying you got eight codes for misfire on all eight cylinders? Did you drive back to the stranded car and read codes or pay someone to tow it somewhere and read them or what? Confused here.
Yeah, sorry bout that. It was another forum where I specified that it was throwing misfire codes on all 8 cylinders. But yes, I had it towed to my friends house then put a reader on it...but neglected to jot them down unfortunately.
Old 10-13-2017, 05:10 PM
XJ8JR's Avatar
Originally Posted by skim7443
From what I can tell, there is no pressure regulator on this model. I was hoping it wasn't the pump, but everything I know is pointing in that direction.
Sorry, its a fuel pressure sensor, not regulator. Mine suddenly sprung a leak once. Small black box type thing on the end of the passenger side rail.
Old 10-15-2017, 09:10 PM
hafren's Avatar
Any good sources on a fuel pump, maybe a ford equivalent that won't cost me 500+$$?
Have a look here https://www.jaguarforums.com/forum/x...-153085/page2/ and https://www.jaguarforums.com/forum/x...-153085/page2/
I believe the pump is a Pierburg 03T260 / 7.28177.01
Old 10-21-2017, 09:20 PM
skim7443's Avatar
Default problem solved
Unplugged the maf sensor and it started right up. Went to autozone and got a new one with a lifetime warranty for $85.00. Drove it home without incident. Think I'll keep an extra one in the glovebox from now on. Who knew it would shut the car down completely while going down the road?! Thanks to all of you who lent me their support on this one
Old 01-30-2022, 01:57 AM
Jagdriver936's Avatar
Default Cranks, won't start.
I changed the maf sensor, crank position sensor & fuel rail sensor. Car turns over but doesnt start. Any ideas?
