04 XJR - how to link key transmitter to memory seat setting
Hi. I would like for my key to trigger the correct memory seat setting when I unlock my car and insert the key. I have 2 keys. My key when inserted uses the previous seat location. I want it to use M1. My wife's key sets the seat to M2, which is perfect. If I drive the car after my wife, the seat goes to M2.
How do I set my key to trigger M1? Anyone know? Thanks.
This should answer your question.
Memory recall using an integrated key
The integrated key will recall a memory position when the unlock button is pressed when set as follows:
1. Insert a key, to be retained in memory, into the ignition switch.
2. Adjust the seat, steering column, pedals and exterior rear view mirrors to the desired positions.
3. Press the M button: The red LED will illuminate for a five second period.
4. Press button 1, 2 or 3 and then press any button on the integrated key. Both button presses must occur while the red LED is illuminated.
5. Repeat for the other integrated key, pressing the remaining memory buttons.
To cancel integrated key memory recall:
1. Place a key into the ignition switch and leave in the OFF position.
2. Press the M button: The red LED will illuminate for a five second period.
3. Press any button on the integrated key (except the panic button, if fitted) then press the M button again. Both button presses must occur while the red LED is illuminated.
Note:
If memory recall is performed using an integrated key with the vehicle in entry/exit position, the steering column and seat will not return to the memorised position until either the integrated key is placed in the ignition switch or the driver’s door is closed.Operating tips
• When making adjustments to a set driving position, reset the new position in the same memory channel.
• A driving position will only be memorised during the five second period when the red memory LED is illuminated.
• Previous memory is erased when a new driving position is entered
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
