04 XJR Navigation Screen Flickering & Communication Fault
Ive searched through the archives but didn't find anything quite like the problem Im experiencing.
Radio and everything works, but it switches constantly between the Jaguar home screen, to the radio, to the navigation, to a screen that has communication fault. It does it constantly, however the radio will continue to work uninterrupted during this. The screen flickers and changes so fast that you can't select anything. I replaced the battery and that didn't solve anything. I did not reset the unit, I tried resetting it a few weeks ago the way I read in other threads but that didn't seem to do anything at all.
I'd appreciate any help regarding this matter!
A hard reset would be the cheapest thing to try first. Basically, disconnect the two battery cables and then touch them together for about 20 seconds or so to discharge the capacitors and re-connect them.
trosty
26
12-18-2022 06:40 PM
rsa760041
23
09-25-2015 01:33 PM
adam699
09-12-2015 05:32 PM
