04 XJR new Rims opinions/critisizim
#41
#42
#44
I have a staggered 19" setup coming for my XJR as well.
Take care,
George
#45
I've have had the XK wheels on both of my XJ8s. The only downfall is it handles better. The ABS works less because the tires have much better traction. It grips the road better too so less traction control interference. Diameter is the same the tires are just wider so there is more road contact area and increased traction.
#46
#47
Where the wheels you put on your XJ8 the same staggered set up as the ones on this XJR? I want to purchase these wheels of ebay as well but I noticed two things wrong. The OP says his tires are 255/40 and 285/35? This seems wrong. I called the ebay seller and told him I had a 04' XJ8 and he said the tires should be 255/35 and 285/30. Can any body help on this situation?
#48
Thank you very much for the comments everyone. I'm glad many of you also like the rims. Unfortunately for the past 2 years the car has been out of commission. The bearing broke and I ended up just selling the XJR to my mechanic. The rims and tire set up was boss tho. Just make sure to avoid the potholes to those who are looking at this set up. The rim dents easily, and the Hankooks have a weak sidewall that can bubble under a strong pothole hit.
#49
#50
#51
#52
The diameter remained the same. Just the width changed. No difference in speedo. My car has wheels from 2010 XKR. They look incredible and no adverse affects observed. I had the same wheels on my 2005.
#53
#56
Also, those 275/35-19 tires you have on the rear are proper size for the XK but a bit small in diameter compared to the 255/40-19 Jaguar recommends, which also contributes somewhat to a firmer ride.
#59
#60
Happy to help! As I asked you before, what rims are you referring to? What size? On mine, the book says 27" diameter.
