04 XJR - Recommendations for wheel spacers?
'04 XJR: I took the right rear wheel off to attempt to fix a slow leak and realized there was some rubbing between the tire and the wheel liner that could actually explain some of the humming noise that I kept hearing all along. There is some rubber missing on the tire. A 3 - 5mm spacer should fix the problem. My research shows that there are quite a few "universal" wheel spacers that fit the car but it appears that it may be a challenge to keep them centered on the hub. Looking for any recommendations on wheel spacers that you may have used that are headache free to install/center.
Rims are standard Sepang 20" and tires are Lexani 255/35ZR20 - the car sits on coil overs (Stutmaster) and it does sit lower than stock due to these coil overs (not by design necessarily)
TIA!
TIA!
I found these too: https://www.summitracing.com/parts/stq-56050253
I wonder if the studs would need to be replaced just to gain 5mm?
Hi, Id like to put 255/40 R20s on Sepangs on my 2007 XJR to soften the ride. My understanding is that a 40 vs a 35 aspect ratio tire will add an inch to the total wheel height. When I look in the wheel well I can see that there is only about a 1/2 inch clearance between the current 35 aspect ratio tire and the upper wishbone ball joint bolt. Will a 40 fit? What am I missing here? Thanks!
