04 XJR Water pump replacement - O ring question
I am in the process of replacing the water pump on my '04 XJR, and am not sure where the O ring should be installed. The water pump was supposedly replaced by the previous owner, but I had two different Jag dealers tell me that it was leaking and needed replacement. I ordered an AC Delco 252-800 pump from Amazon (couldn't believe they were cheaper than Rock Auto) and it arrived with a steel gasket and an O ring. Taking the old pump off, there is no O ring to be found anywhere, so I'm not quite sure where I'm supposed to install it. I've checked several parts diagrams, but I can't figure it out. My guess is that it should be placed on/in the block and the pump presses against. Can someone please confirm?
Did the AC Delco pump come with instructions?
I can only relate to the 2000 S Type water pump.
I replaced with the steel gasket and I thought the O-Ring goes on in front of the metal gasket.
Also, I used Hylomar on the steel gasket for extra insurance.
I'm sure others will chime in here.
Another thought... the OEM Jaguar water pump used 2 O-Rings I believe - I find it bizarre your pump had no O-Ring. (maybe the cause of your leak) Be sure to check the cavity where the water pump sits on the block to ensure it's not wedged in there, somewhere...
Don B (07-28-2014)
The pump had instructions, but it made no mention of the O ring. They appeared to be generic. I did double check, and there was not an O ring anywhere to be found on the block or the pump, which I believe is why there was a slight leak.
There was a groove in the new pump where the O ring appeared to fit perfectly, so instead of placing it on the block and having the pump compress it, I installed the ring into the groove, and assembled it on the block. I didn't use any additional sealer thinking that if it does leak, I'll take it apart and try putting the O ring on the block. If anyone else has done this procedure, please let me know where you installed the O ring.
Thanks.
Thanks.
I used an aftermarket water pump. Another forum member highly advised using the Hylomar as additional insurance. Instructions do not specify using sealant on the metal gasket.
This was a personal preference of mine for peace of mind...
It's been 2 years since replacing the pump and no issues. In looking at a few pics of my install - I did install the O Ring in the groove on the pump.
Don B (07-28-2014)
