05 VDP transmission or engine mount?
Old 06-21-2023 | 09:36 PM
Deepstuff's Avatar
Default 05 VDP transmission or engine mount?
Hi,
In my new to me VDP, I feel a bump just as engine starts, and also feel a bump when get into the gas to pass on the highway. I'm thinking engine or transmission mount? What's the usual suspect? My car has 93,000 miles.
Tks.
Old 06-23-2023 | 12:16 AM
abonano's Avatar
Could be either but sounds like an engine mount.
If trans mount car would feel movement when going in R from Park.
Old 06-23-2023 | 11:42 PM
Panelhead's Avatar
Default Engine mounts
Engine mounts are the easiest to check. With motor running place car in drive and with brake applied increase tpm. That is mount that normally fails. See if engine lifts.
The place in reverse and with brakes applied,raise rpm to check engine movement.
i doubt there is a good check for the transmission mount. Usually change to see if that helps.
Tranny might benefit from a fluid service.
Petz (06-24-2023)
Flex320
XJ XJ12 ( X305 )
01-05-2023 01:12 PM
JagXtypeV63.0L
11-28-2020 08:19 AM
kazi
02-24-2020 09:46 AM
Higgins
02-20-2019 06:50 PM
kyle04
09-26-2013 07:51 AM
Quick Reply: 05 VDP transmission or engine mount?
