'05 XJ8L Starter Problem
Old 06-08-2016 | 07:37 PM
Ben7's Avatar
Question '05 XJ8L Starter Problem
I have a '05 XJ8L Starter Problem. The car has virtually a new battery and was working fine. It usually sits up a lot in the garage and I had not put a battery tender on it. But the last time it cranked just fine , ran the engine a few minutes put it back in garage, went to take it out last weekend and it want crank. Put a battery tender on the battery in trunk over night and in morning the green indicator said battery was charged. But everything is dead when I open the doors no lights come on or the dash like usual. When I try to crank, everything is dead, it doesn't even try to turn over. Also when I put battery tender on it there's is this clicking sound even when I put the trunk down? Suggestions what the problem is?
Old 06-08-2016 | 08:20 PM
grantorino62's Avatar
I would suspect a loose or corroded ground cable. I would remove and clean the ground cable at both ends and clean it. Be careful, the stud is aluminum and easily broken on the body. There are two ground studs just behind the headlights or either side. Remove the plastic cover on the radiator support to see them. Again be gentle! aluminum stud on an aluminum inner fender. Same thing, clean the wire ends with electric spray cleaner, no sand paper or wire brush. Then reassemble.
Old 06-09-2016 | 11:24 AM
Rickkk's Avatar
I would make sure that the battery clamps are clean and snug.
Old 06-09-2016 | 04:41 PM
Ben7's Avatar
Question
Battery cables look basically brand new and are snugged. I will try grantorino62 suggestions when back in town. grantorino62 on your quote, "There are two ground studs just behind the headlights or either side."
Is that "or" suppose to "on"? In other words, on both sides?
Old 06-10-2016 | 08:49 AM
Yes, both sides.
Old 06-12-2016 | 02:40 AM
Ben7's Avatar
Arrow
These are the studs grantorino is talking about? "I would remove and clean the ground cable at both ends and clean it." If I got the correct end for each side, how do you clean the ground on the other end? Seem like the other end is running back into the car hidden or unreachable? (Excuse me, I'm a newbie lol)
Driver side
Passg side
Old 06-12-2016 | 09:34 AM
Yes, those are the studs. BE GENTLE! They say that they're easily broken taking the nuts off or upon reinstalling.
Old 06-12-2016 | 03:50 PM
Ben7's Avatar
I cleaned both sides. How do you reach the other end, seems like the other end is running back into the car? Anyway, cleaning both sides of these studs didn't help. Battery tender has battery fully charge but when I open the car door no lights come on nor does the dash mileage doesn't light up either. More suggestions???
Old 06-13-2016 | 09:07 AM
Ben7's Avatar
Can you all give some more troubleshooting that I might can try to get this started? Can't even take it to a mechanic without getting out of the garage...
Old 06-13-2016 | 07:09 PM
meirion1's Avatar
I would start at the battery and the battery earth.
There is a copy of the Jag electrical ciruit on the sticky page.
Diag. 1.1 shows a transit isolation relay and the megafuses.
You will need to check that there is power after the megafuses first.
ImNotFamousAnymore
10-02-2022 05:28 AM
alynmurray
04-04-2016 11:12 AM
wforslund3
03-31-2016 01:14 AM
Dean Kitching
03-30-2016 03:53 PM
phil51
03-25-2016 09:18 PM
Quick Reply: '05 XJ8L Starter Problem
