05 XJR rattles from front end
this really drives me nuts and i hope someone can help me with it,,
my 05 XJR started to rattle from engine bay,, i believe the engine itself rattles,, it rattles just like nuts in a jar,, the symptom can be described as the following:
please,, help,,
- it rattles in partial throttle on higher gear especially under load
- rattles faster and louder as i press the gas pedal until engine sound takes over
- no rattle if revved in neutral
- all pulleys sounds ok
- all covers/plates may wiggle removed from engine bay
- revert back from MG CAI to stock air box
- spare plugs replaced
- coils checked ok
- engine oil changed
- rattle is completely independent from road surface and driving conditions
- car performance is noticeably reduced
- had a "restricted performance" twice and it went out immediately
- even poured a bottle of liqui moly fuel injector cleaner in a full tank
please,, help,,
According to my jaguar document P1646 is HO2 sensor control malfunction bank 1 upstream. ??
Looks like you need to replace it and perform two drive cyles before amber light reappears if problem remains
HEATED OXYGEN SENSORS MONITOR DRIVE CYCLE
Upstream (Universal) oxygen sensors:
1. Engine OFF; cooling fans inoperative > 20 seconds.
2. Start engine and bring to normal operating temperature > 82 °C (180 °F).
3. Drive the vehicle between 3000 – 4000 rpm in 3rd gear at a steady speed. Lift foot completely off accelerator
and coast to a stop within 30 seconds. Do not touch accelerator pedal for 4 seconds after coming to a stop.
4. Repeat step 3.
4. Repeat step 3.
5. Idle engine for 11 minutes.
google code plenty of info around
i totally agree,,
but still can't find a reason behind it,,
i checked short and long term fuel trims and they're perfect which eliminates fuel starvation and intake vacuum leak,, fuel pressure is always close to 60psi,,
could it be high IAT as i sometimes get a P2601 which relates to SC coolant pump? what is the normal operating IAT?
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
