06 XJ Vandenplas - Fuel door won't open? HELP!!
Hi all,
The fuel door won't open on my 06 XJ Vandenplas -- the door is opened electronically via a switch panel on the dash, other buttons on the panel are working (trunk switch for example). Any thoughts on what could be causing the door not to open?
I've been told to check the following - check all 3 fuse boxes (under passenger side dashboard, trunk, and under the hood).
Thanks!
Thanks!
This probably won't be much help, but I have a 7-step procedure I generally use when refueling my '05 VDP:
1) Reach down & press release button.
2) Get out of car and walk around to fuel filler - not open.
3) Go back to driver's door, reach in & push release again.
4) Walk back round to fuel filler again - still not open.
5) Slap forehead, curse, and close trunk lid.
6) Go back to driver's door again, reach in and press CORRECT release button.
7) Walk back around to fuel filler again and fill fuel tank.
![Icon Idea1](https://www.jaguarforums.com/forum/images/smilies/icon_idea1.gif)
Last edited by Kilowatt3; 02-12-2013 at 05:15 PM. Reason: Ooops - Trying to Delete the duplicate message, but can't figure it out!
The following 2 users liked this post by Kilowatt3:
Fairlane500 (02-13-2013),
vacmail (02-15-2013)
99xk8guy
06-05-2023 06:28 AM
