06 XJR Fuel Pump/Fuel Leveling gone bad
Ran out of gas in my 2006 XJR way before tank was showing empty. Turns out the fuel level has malfunctioned (obviously). Unfortunately I am being told that I must replace two fuel pumps totaling 1600 in parts and labor. All this to ensure I know how much fuel I have in the car. Jag dealership in vegas is telling me that I cannot just fix the leveling issue by itself- I must replace both pumps. Is there a more inexpensive fix here?
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
That quote for the fuel pumps is about normal,the cheap way is to do it yourself,its about a 4-6hour job for the dealership.The parts from Jag are about 400.00per pump and strainer,so parts 800.00+ 800.00 labor= $1600.00.I'll bet the fuel sensing sensor is working fine and will not have to be replaced.The other part they may replace is the wiring harness which also can fail or breakdown.Good luck and keep us posted.
Wolfy
05-28-2024 08:06 AM
deanh
09-06-2015 08:20 PM
