06 XJR got a little too hungry and ate the SC rotors
Old 02-29-2024, 09:38 AM
JagsteRJX's Avatar
Default 06 XJR got a little too hungry and ate the SC rotors
It could be all she wrote for my 2006 XJR. On the weekend it ingested debris from the SC rotors into cylinder #1. Eurocharged Cincinnati rebuilt the SC 2 years ago, everything they touched on my car they screwed up.
As the car now has 181k miles on it I don't think it's worth repairing or installing a new motor in it. The rest of the car is in good shape, just installed new brake rotors on the rear and 4 new Michelin PS4 A/S tires on it a few months ago.
I knew my XJR was getting on in age and may not last much longer, I ended up purchasing a 2017 Benz S550 last year as my primary car, my XJR became the run it until it dies backup car.
Any recommendations on what to do with it?
Old 02-29-2024, 10:24 AM
JoeDredd's Avatar
Breaking the car yourself is always one of those good in theory ideas. A work collegue has an Audi TT he is breaking and has to deal with clowns wanting stuff for nothing, people not collecting plus the irritation of a festering car corpse on the drive. Get a breaker to take it away.
The following 2 users liked this post by JoeDredd:
87LC2 (03-04-2024), Thermite (04-01-2024)
Old 02-29-2024, 04:35 PM
Wingrider's Avatar
Sorry to hear about your bad luck, you might consider looking into a used motor.
Old 03-01-2024, 08:27 PM
paulz67's Avatar
If anything, I see an amazing number of wrecked and/or broken early XFs for sale online, given the demographic those cars attracted, especially for third and fourth owners. 2009 cars had the 4.2, so perhaps one could more easily lay hands on a SC engine that way?
Paul
Jaroslav Záruba (04-09-2024)
Old 03-01-2024, 08:53 PM
TommyBoah's Avatar
Paul
Assuming nothing much was changed internally, that'll be a good option
Old 03-02-2024, 05:49 PM
VR6Rado's Avatar
How's the rest of the car aside from the engine and supercharger? If everything is in otherwise good shape and was working well, maybe it would be worth it to put in a used engine and SC, especially if you've already combed through the rest of the car and know that the bones are good. If you've done a lot of repair work and prevenative maintenance already, the odometer reading doesn't really mean that much.
Sometimes it's better to deal with the devil you know than the devil you don't.
Scouring local yards can yield great results that can save you some dough, especially if the staff don't realize what they have. I was able to get a good used engine, SC, and trans all as one piece from a wrecked, 80k mile S-Type R for a little over $500 last year. The staff thought it was just some regular old S-Type
The following 4 users liked this post by VR6Rado:
2ndeagle (03-09-2024), paulz67 (03-02-2024), rsa760041 (03-04-2024), Wingrider (03-04-2024)
Old 03-03-2024, 08:59 AM
JagsteRJX's Avatar
Taking a quick look for used engines online I did see an 09 XF 4.2 SC with 80k miles for $3k. My mechanic quoted $7k to perform an engine swap, this price seems high. However, I don't have the tools or time to perform the work, so a mechanic would have to perform the swap, the total price would be $10k for engine and labor.
The transmission is original, I've performed a full fluid change and installed a maintenance kit (new filter/pan, internal rubber pressure grommets and plastic plate) on it once.
I've taken the high pressure manifold off and exposed the SC, it doesn't appear that bad, I thought it would be a lot worse. I'll remove the SC and perform a full inspection of it.
I didn't see any debris in the intercoolers either, I was surprised they were still clean from the cleaning I gave them 2yrs ago.
Old 03-22-2024, 07:47 PM
JagsteRJX's Avatar
I managed to remove the SC and didn't find any damage to it or likelihood of it being the cause. I checked the #1 cylinder with a borescope and saw no issues there either. I'll check the other front cylinder, as the mechanic said it was one of the front cylinder. If there's no issue with the front cylinders, them It's possible it could be a timing chain/tensioner issue.
Old 03-24-2024, 02:48 PM
clubairth1's Avatar
Received 2,488 Likes on 1,950 Posts
Have they been changed or still original?
Old 03-27-2024, 08:30 AM
JagsteRJX's Avatar
I doubt it, I've owned the car from 55k miles, it now has 182k miles on it.
Old 03-28-2024, 07:31 AM
clubairth1's Avatar
If you got 182K on the OEM stuff you are a super star!
I would gladly fix a car that lasted that long if I liked the car.
Hope your pictures show no piston-valve contact too. I have heard if it jumps one tooth you might be OK but if it jumps more than that it's collision time!
Old 03-29-2024, 10:49 AM
JagsteRJX's Avatar
I decided to purchase a $30 borescope, unlike Bono, I managed to find what I was looking for.
R.I.P Jagster.
Old 03-29-2024, 12:03 PM
Wingrider's Avatar
OUCH
Replacement engine maybe?
Old 03-29-2024, 03:52 PM
JagsteRJX's Avatar
Originally Posted by Wingrider
OUCH
Nah, I think it's time to say goodbye to the Jagster and sell it, it would make a good donor car, as there's no other issues apart from the engine.
Old 03-30-2024, 08:58 AM
clubairth1's Avatar
Looks bad but I can't figure out what it's showing?
What are the black round things?
Old 03-30-2024, 09:15 AM
Wingrider's Avatar
Pistons are the round objects,along with chunks of metal inside of the combustion chamber.
Old 04-01-2024, 09:52 AM
Thermite's Avatar
It's mostly labour.
ONCE (only, ever..) timed a FIAT 124's DOH Cams 180-degrees out of phase. Cost me new valves, guides, seals, pistons. Did rod & main bearings, new gudgeon pins, hand honed bores, hand surfaced block deck and head on principle. Came good with smooth power, lower oil consumption than factory new.
BMW six cracked the head it came in the door with and two Netherlands-done rewelded ones after. It, too, had to be gifted new bearings, pistons, rings, and valves.
Both of those, and a few more 'merican made rockerboxes were done in the vehicle. THAT part I will no longer consider, what with age and stiffness earned over nigh-on 80 years.
Gots to order meself a new engine stand for the L320's 5.0.
Keeps me out of pubs and brothels.
Can yet-another used car promise you that LAST part?
Might want to rebuild the Jaguar's mill after all?
Not because it makes economic sense.
Just because you can.
Old 04-08-2024, 09:06 PM
bagpype's Avatar
Are you willing to sell me a couple parts off of it! I’m in Cincinnati till tomorrow. If you are, let me know and I’ll come buy what I need.
Old 04-09-2024, 09:28 AM
JagsteRJX's Avatar
I'm in Florida and I'm selling the entire car. It's listed in Marketplace on this forum.
Old 04-09-2024, 10:05 AM
Thomas-S.'s Avatar
I would rather say that the round black objects are the valves, you can see the valve seat of the bottom one.
In any case, OUCH is the correct term. Even if the original damage is "only" the cylinder head, I fear that metal particles have damaged the cylinder itself.
Best regards,
Thomas
Quick Reply: 06 XJR got a little too hungry and ate the SC rotors
