08 xj cats,abs,srs fault
I bought an 08 hit in the front fight lite. I replaced the front right fuse box but air ride doesnt come on, i checked all the fuses and there where good under the dash on the right and trunk i dont think theres another fuse box. but if anyone has any great info they can share.
There are 3 fuse boxes,one under the bonnet,one in the boot and one in the cabin.
If you PM me your email address I will email you a 91 page electrical wiring diagram in .pdf form (its from a 2003.5MY car but I would think most will be the same), this shows fuses,circuits,wiring,modules,and anything else to do with the cars electricals.
Whats a fight lite?
Whats a fight lite?
jgm,
The air suspension system has a total of 3 fuses and 1 relay located in two fuse boxes. If you want to do a cursory check of these:
In the engine compartment fusebox look at the 40A fuse #6. This operates the air pump. In addition, same fuse box, look at the brown relay, position #1 also for the air pump. If you suspect the relay, try switching it with R2 just to try for operation. R2 is the RH main beam, so not too much impact if R1 relay is bad.
Next, go to the trunk fuse box. Look at two fuses there. F12 is a 10A fuse and F52 is a 20A fuse. Both of these are assigned to the air suspension.
In process of elimination, these are the easiest checks, but I am going to suggest, with a right front collision, you might have more serious air suspension issues like a damaged RF level sensor to name just one.
Keep posting, let's see how you progress.
jgm,
There are 4 level sensors, one at each wheel. You might be thinking about the acceleration sensors. Was the headlamp completely destroyed RH side and do you have HID?
Also, where did you acquire the Engine comp. fuse box? New or used? The fusebox is high risk buying used as there are a number of non-replaceable relays built into the fusebox PCB. Some ebayers, for example, sell these on Ebay probably not knowing the PCB is bad, junkyards too.
I'm tryin to pm buckmr2 but I don't know how. But my email address is nfsjgm2@gmail.com
Email addy there is the best way right now.
jgm,
ericjansen
12-19-2021 12:20 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
xjrjag
09-24-2015 10:08 PM
