Hi. In a bit of a pickle here. Replacing the rear wheel bearings and the left one just slid off, but the right one was not interested in coming off. Of course you can't undo the nut without another small wrench holding the bolt itself. Not a great design in my opinion. Anyway, I eventually had to grind the bolt off which of course took a chunk out of the bolt thread. Would anyone know if the bolt can be replaced or do I need to replace the whole control arm?
Ouch ! I would certainly not be putting that back on !! I reckon you've ground away about half the thickness, and probably reduced its strength by at least 50%. Parts like this are mission-critical.
Never had luck with nut splitters. I usually grind slots on both sides with a Dremel tool and hit it with a chisel so it cracks. Same basic idea as nut splitter, but this method works for me.
